Furnace stopped working. Upon checking noticed the igniter had cracked, so replaced with an OEM igniter. When I restarted the furnace the blower motor started, ran and stopped. The LED indicator light just blinks rapidly indicating the 115 line voltage polarity is reversed. I have not even touched the line voltage. Used a tester and polarity was correct. Then I reversed anyway just to see if that would correct the problem. It did not, so changed back to the way it was originally.
Unable to run test sequence on Payne Furnace
by FordMan59The reason for this thread is for people who are looking for cheaper/easier to find alternatives to MPI products and want to know how well they last....
Channel: Monitor Heaters
