troubleshoot gas wall heater- thermostat? wire?
  • lilafter
    • Jan 2007
    Hi, I have a older (15+years) cozy direct vent gas wall heater with the original manual thermostat wall control (2 wire).
    Last year, the gas valve was replaced after replacing multiple thermopiles ( pilot would go out).
    Its been working fine until last week- the pilot stays on but the gas valve doesn't "open" unless I give the valve a little whack. then the gas valve will be responsive to the thermostat for a bit then non responsive after.
    I tested the thermostat with a jumper cable- no response
    I tested the TH TH/TP on the gas valve with a jumper cable- fired up and then right after tested the thermostat- it fired up.
    Is the issue a faulty gas valve, faulty wire or thermostat?
    I hope the issue isn't the gas valve it was expensive to replace.
  • akaothermick
    Absolutely incompetent
    • Jan 2014
    • 140
    Clean all connections to bright metal including the wires, clean thermocouple base in the gas valve and reseat it.
