You dont say if the AC can slide out of the case. If it can pull it out to clean the drain runs out. If you cant see them from the outside you will have to pull the whole cover case off of it to get to the small drain pipes or groves in the bottom of the AC. Like was said it does tilt to the out side dont it.
