Lost here can it be in defrost??? When its in heat the fan should be on and it should blow cold air outside and warm air inside. Id call a hvac service guy to look at it. When you first go to heat there the fan outside and inside should be on
the heat pump is like a standard a/c with one exception. There's a reversing valve in the freon line. at one point the evaporator is an evaporator at the other it is like the condensor and gives up heat. check to see that is working first!
Has anyone had an occurrence of a Laser 730 or 731 over firing? The top of the heat chamber and the heat exchanger glow red on high when this occurs....
