Furnace Problem
  • SpongeBob
    • Jan 2005
    Furnace Problem
    We have a 7 year old Lennox Model 80MGF furnace and the following problem has recently started:
    When the furnace starts up, the burner cycles for about 2-3 seconds then quits. Then it starts up again and the furnace works fine. Any ideas would be greatly appreciated.
  • Dean
    • Dec 2004
    • 43
    Really need to be there with testing equipment to catch it in action but just a [u]guess</u> would be the flame sensor or Ignition Control Module starting to go bad.
    Sometimes you can clean the flame sensor with steel wool or very fine sandpaper
    • mr fix it man
      • Jan 2006
      • 6
      try changing filter first.
