If You can see the label on the capacitor with three terminals you will see that it is a dual capacitor. They are often used so that one capacitor can serve both the compressor and the fan motor.
A dual capacitor is simply two capacitors built into a common housing, where the center terminal is the common terminal for both capacitors.
The brown wire on the dual capacitor is the wire for the fan motor. you will be removing that wire when you pull the old motor.
The new motor has two wires to the capacitor so there will be no wire from the new motor to the dual capacitor. The fan terminal on the existing capacitor will be left disconnected.
