i have a propane furnace and noticed recently that the blower is turning and off several times during the heating cycles. at first it only shut off and turned on twice during the heating cycle. this morning the frequency was much more. any ideas?
blower cycles
This could be normal operation - if the heat inside the furnace gets to hot then your safetys will cut off the gas valve. Could mean that you have a capacitor that is going bad on the blower motor, safety switch is getting week and not detecting the proper temps, or several other things. If you are not up on working on your heater call a pro out to check it out.
Brandon
- Have you changed your filter this month? -__________________________________________________
Brandon
Channel: Toyo Heaters
