Gas Furnace won't Restart
  • Janet_home_owner
    • Dec 2005
    I am a first time home owner, yeah!! I have a four year old house with a brand new furnace that's that old. Just yesterday, my furnace won't restart automatically. I manually started up it up by lighting the burner. The fan starts and the gas is emitted but won't light up as usual. Once the temp is reached at the desired level, it stops and won't light back up? What should I do?[:I]
    Thanks is advance.
  • lonestarheir
    • Jul 2005
    • 137
    This unit probably has an automatic ignitor that has failed, your best bet unless you are comfortable using electrical testers is to call a pro out and let him fix it, could possibly even be in warranty. If you will get us the model and serial #'s someone on here will be happy to give you that information.
    Brandon
    Brandon
