flexible gas line
  • flexible gas line
    I am installing a gas insert in my wood fireplace that requires bringing the gas line all the way around the house. One plumber wants to use the standard Iron and the other a flexible yellow gas line. From my research the flexible is rated to -100 degrees which is more than enough for where I live in Alaska but the other plumber says it is more likely to harm being outside. It will be attached to the house about 5 feet off the ground. It is much cheaper.
    what do you think?
    Alaska Guy
    Alaska Guy
    what do you think?
    Alaska Guy
    Alaska Guy
      both sound like they will be ugly if not covered in some sort of conduit,flashing,ect. Corrugated Stainless Steel Tubing (csst) is a great product, I would not hesitate to use it in this project, I would find a way to cover it, it installs quicker then black pipe but the tubing it self is pricey, you save on labor
