I am installing a gas insert in my wood fireplace that requires bringing the gas line all the way around the house. One plumber wants to use the standard Iron and the other a flexible yellow gas line. From my research the flexible is rated to -100 degrees which is more than enough for where I live in Alaska but the other plumber says it is more likely to harm being outside. It will be attached to the house about 5 feet off the ground. It is much cheaper.
what do you think?
Alaska Guy
Alaska Guy
