Hello, I did a little more research and found that the ouside unit fan blades turns on, to me that shows that the unit is functioning no bad caps or switches correct?. However, When I'm in the house and turn the thermostat on I used to here the filter being sucked up a little once the A.C. starts blowing. That is not occuring anymore. Any ideas? filters changed regulary.
Heres a question does the heating unitin the attic have anything to do with the AC unit outside? if so, then my question is during the winter ,the heating units vacuum switch (looks like an oreo cook) was clogged never allowing the heater to turn on. After clearing the passage worked well. Could that possibly be a problem? with the AC unit. Thanks
any tips, things to check Thanks
Good Morning, I hope someone can help. I have a York 2 or 3 ton unit outside for my down stair that for some reason as of yesterday when I lower the thermastat nothing happens. When I shut the unit off in the house and restart it I here, I guess the fan motor start, but that is all. I have noticed that recently is has not been blowing the cooleset of air but that could be due to high ceilings and really hot climate. Unit is 6 years old never been serviced. I believe model number starts out like "York HRRA0505360"
Any assistance will be greatly appreciated
