HELP w/thermostat install!!
  • jsomethin
    • Nov 2003
    Hi,
    I hope someone out there can help me. I recently purchased a new Hunter 44150B thermostat.
    I'm replacing an older thermostat and the instructions on my Hunter describe different wiring scenarios, but I can't find my particular wiring scenario in them. I'll try to describe how mine is currently set up:
    | 4 |
    | Mercury |
    | dial |
    | 9432 E7 2 no marking |
    So.....
    - There is a white wire that connects the upper left terminal marked "4" to the unmarked terminal on the lower right.
    - There is a yellow wire that connects the glass tube of mercury to the disc.
    - There is a brown wire that connects the glass tube of mercury to the unmarked terminal on the lower right.
    - There is a blue wire that connects the glass tube of mercury to the lower left terminal marked "9432 E7 2"
    The only corrleating wires in the Hunter instructions I can find is the terminal marked "4" corresponding to what they call "RH".
    So...any help that anybody can provide would be greatly appriciated.
    THANKS!
    -Jerry
  • jsomethin
    • Nov 2003
    anyone?
