Help please....Carrier 58PAV furnace blower continues running even when furnace is completely off! Comes on for approximately 5 minutes shuts off for about 5 -10 minutes and comes back on and so on...
check your high - low limit in the air plenum. it operates on a proportional band between two set points. because hot air rises, even with the burner off residual heat works its way up and sets off the fan limit.
Has anyone had an occurrence of a Laser 730 or 731 over firing? The top of the heat chamber and the heat exchanger glow red on high when this occurs....
