loss of flame on lp gas furnace?
  • bear57
    • Oct 2006
    I have a york lp gas furnace (95) that starts correctly, then I lose the flame.
    The diagnostic code indicates Loss of flame. I need help solving this problem. Thanks - Bear57
  • hvacwiz
    • Apr 2006
    • 97
    you have in your furnace what is called a flame sensor, looks like a straight metal rod located in front of either the far right or far left burner with 1 wire attached to the top of it, remove it with 1/4 inch nutrunner and use sandcloth to clean it off should take care of your problem
    • bear57
      • Oct 2006
      Thanks hvacwiz
      I sure do appreciate your response to my problem. I tried your solution and it worked perfectly!! bear57
