By the suggestion of a licensed HVAC tech, I installed check-valves into both Zones of my heating system to prevent 'ghost-flow' from happening when one zone is on. Since then, when I start the system, it will take 1 to 1 and 1/2 hours to heat up the entire zone. And by then the first room it heats gets up to 75-80 degrees, whereas the last room is just hitting 70 degrees.
The temperature of the boiler is fine.
I have bled all of the air out of the system (I believe) in both zones.
I have plenty of experience soldering so I do not think there is an obstruction in the copper.
The check-valves I installed were from Lowes. They had 1 input and 1 output and the inside was that plastic piece that moves back and forth with pressure.
Please see the attached diagram. Zone 1 is the main floor of the 1500 sq. ft. ranch home, and Zone 2 is the basement. Both zones circle around the perimeter of the house.
Any suggestions (besides getting a tech in)?
