New Furnace Data Comparison
  • berzerker2
    • Nov 2003
    I am buying a home and am in a position to suggest to the seller what brand and model gas furnace to replace their old Consolidated unit (leaking heat exchanger) with. Has anyone done a comparison recently or know of a website that provides this type of data WITHOUT charging $10 or $20?
    The home is a tri-level with 1400 sq. feet. I will most likely go with an 80%, single stage unit but don't know what brand has the least amount of trouble or which is the best value, etc.
    Thanks in advance!
    Bryan
  • Hube
    • Nov 2003
    • 453
    If your going to be in this home for a few years, your better in the long run to go with a HI-eff Furnace.(90-95) It may cost more to buy, but will save you $$$ on fuel bills down the road . HEIL,LENNOX, have proven records, but the Contractor's installation is what really counts no matter what FURNACE you buy. Insist on a 2 speed fan with a controlled (switch) "low "speed (for better air circulation) Also a new "Set-back" thermostat will save you fuel...Good luck, Hube
