Goodman Wiring Instructions
  • ripbearer
    • Nov 2003
    I have an A36-15 GOODMAN Air Handling Unit w/ Heat Pump and I'm trying to hook up a Lux TX9000 thermostat.
    On the wiring terminal block inside the air unit
    Red thermostat wire goes to R Terminal inside air handler unit
    Yellow thermostat wire goes to OT-3 Terminal inside air handler unit
    Green thermostat wire goes to G Terminal inside air handler unit
    White thermostat wire goes to W2 Terminal inside air handler unit
    Blue thermostat wire goes to C terminal inside air handler unit
    Orange thermostat wire goes to O terminal inside air handler unit
    Brown thermostat wire goes to E terminal inside air handler unit
    I need wiring information.
    Sincerely
    Brad R Armstrong
