I have an A36-15 GOODMAN Air Handling Unit w/ Heat Pump and I'm trying to hook up a Lux TX9000 thermostat.
On the wiring terminal block inside the air unit
Red thermostat wire goes to R Terminal inside air handler unit
Yellow thermostat wire goes to OT-3 Terminal inside air handler unit
Green thermostat wire goes to G Terminal inside air handler unit
White thermostat wire goes to W2 Terminal inside air handler unit
Blue thermostat wire goes to C terminal inside air handler unit
Orange thermostat wire goes to O terminal inside air handler unit
Brown thermostat wire goes to E terminal inside air handler unit
I need wiring information.
Sincerely
Brad R Armstrong
Sincerely
Brad R Armstrong
