No spark-Lennox gas furnace
  • irregularjoe
    • Nov 2003
    • 176
    Hi. First time poster.
    My Lennox gas furnace will not light. I checked the relays, bypassed limit switches. Stat is ok. I hear the gas valve click when I set the stat to heat. Can't get spark at the ignitor. I checked all wires, and are ok.
    Would this be a ignitor controller problem? Or gas valve?
    Here are the specs:
    Furnace- Lennox
    model# G1603/4-100-1
    Ignitor controller panel- Robertshaw
    model# SP735L-Lennox P/N 1869101
    Gas valve-
    Robertshaw Grayson
    7100 der?S7C
    71F-11A-017
    Thanks, Joe
  • irregularjoe
    • Nov 2003
    • 176
    anyone? it's getting cold.
    • Hube
      • Nov 2003
      • 453
      Have you tried cleaning the terminals (contacts) of the ignitor/ or gas valve wires?. Sometimes they get corroded, etc. Hube
      • irregularjoe
        • Nov 2003
        • 176
        all the wires and contacts are good.
        • Hube
          • Nov 2003
          • 453
          Then it must be a fault in the gas valve or ignitor. Check resistance (millivolt? or 24 V..? Hube
          • irregularjoe
            • Nov 2003
            • 176
            yeah, I assumed that. I'm trying to determine which. Ignitor or valve. I really don't want to buy both.
            • irregularjoe
              • Nov 2003
              • 176
              check resistance of what?
              • irregularjoe
                • Nov 2003
                • 176
                OK. Latest results. I DID have some rust on one of the valve terminals that I did not see previously. Cleaned it, still NG.
                I have 24 VDC going to the main ignitor control, but nothing coming out. What triggers the conrtoller to send 24 volts to the gas valve? I jumpered it out and the gas valve does open.
                • irregularjoe
                  • Nov 2003
                  • 176
                  I can apply 24 volts directly to the gas valve and can get both the pilot and main ports to open. (or at least I hear them clicking)
                  No ignitor though.
                  I'm assuming that the ignitor controller is the culprit.
                  Any thoughts would be appreciated.
                  • irregularjoe
                    • Nov 2003
                    • 176
                    anyone know if robertshaw SP735L-Lennox igtion controller is available? can't find it online.
                    • irregularjoe
                      • Nov 2003
                      • 176
                      Well I have heat again after 10 days without it.
                      I found a complete ignition kit at Graingers for $150. Ignition control panel, gas valve , and ignitor. It's a Robertshaw package (P/N 712017) and replaces the SP735. (which is obsolete).
                      It took 8 hours to install, as it was a different wiring configuration and nothing really fit correctly without some modification. Trying to install the damn ignitor was the worst part. But we have heat now. Personally, I could have got through the "winter" without it (78 degrees today) but my S.O. sure is happy!
                      • Troy
                        Moderator
                        • Jul 2002
                        • 576
                        I hate noone here was much help, you've been helpful to so many!
                        Try
                        • irregularjoe
                          • Nov 2003
                          • 176
                          Thanks, Troy.
                          I knew it had to be either the control panel (99% sure) or the gas valve. I just didn't want to buy one and then find out it was the other. So when I found Grainger's kit complete with the above mentioned two items PLUS the ignitor for LESS than the price of just the control panel at all the supply houses, I figured it was a no brainer. Don't know why I didn't consider them sooner, as there's a branch right here in town and I bought things from them years ago.
                          But..........On to the next crisis, I guess.
