Mini-Duct AC system - home owner install?
  • AMontemagni
    • Nov 2005
    • 30
    Has anyone (non-contractor) installed a mini-duct AC system in their house?
    I have a L-shaped ranch, with easy access into every room (whether through the attic or basement) and I'm considering installing one of these systems.
    Any pros / cons of the system?
    what do you mean "mini-duct?" I have installed a complete heating system using snap together duct work and other ductwork I fabricated. for this type of ductwork check out DUC-PAC in East Longmeadow MA.
    • AMontemagni
      • Nov 2005
      • 30
      I mean the small 2"-3" diameter duct sections. And the compressor is usually installed in the attic, with all of the registers in the ceiling of the rooms.
      But I will check out DUC-PAC - I will one town over.
      • AMontemagni
        • Nov 2005
        • 30
        I mean I live one town over
          It's rather unusual to have a three inch duct. three inches isn't much for air flow! even a typical dryer hose (4 inch) is small for cooling. a flexi insulated fiberglass duct seems a little more efficient. I
          doubt you can find a register boot for three inch but you have a better chance using 6 inch You're one town over ?? Springfield? Agawam? I used to live in Greenfield/ Turners Falls area for 29 years.
          • rajjoshi@aol.com
            • Mar 2007
            High Velocity AC
            Are you talking about one of the High velocity air-conditioning systems like Spacepac? If so, they work really well. You can put the unit in the attic, or in a closet. You also need space for a return....which can be in a ceiling. The system cools things down very quickly and dries things out about 20% more effectively than traditional AC systems.
            • AMontemagni
              • Nov 2005
              • 30
              Yes, a High velocity air-conditioning system
              Yes, a High velocity air-conditioning system, that is what I was referring to.
              Does anyone have any knowledge about a home owner installing one of these systems? How complicated? Any idea on costs?
              • mud
                • May 2006
                • 9
                I've installed a couple a few years back and they worked very good. Proper design is critical for good operation. I would recommend a conventional duct system if it's an option. If not go with the hv system (i used spacepak) making sure sure it's designed right including length of each duct. I know when i installed them all the sizing could be done on their website, not sure if thats still the case.
