why is my a/c drip pan full of water and overflowing? i've included a few pics to help explain. i've checked for cloggs in the tube coming out of the pan and it seems to be fine. i used a bicycle pump and air easily rushes through. i stuck a metal coat hanger down the tube that goes into the floor to check for a clog and it seems to stop just below where the other one meets, i think their is another bend their??? anyway, it's been 101 degrees so i'm sure the a/c has been runnng alot.
a/c drip pan full
Tags: None
i did find where it exits the house outside and was told to spray the hose up it from the outside and try to unclog it............that didn't work.Comment
try from inside then, but you will need to plug that connection on that pan, and feed the hose down too that Tee fittingIs it beer thirty??Comment
Late Post Here
The picture posted has other issues.
First of all the drip pan is for emergency leaks and should not be full of water at all times.
If the pan has water in it, it is a indicator that the primary drain line is obstructed. Water is backing up back into the evaporator coil and draining from the bottom into the pan.
In the picture, the red plug is intended to the secondary drain line which should not be blocked. This should have a PVC pipe attached to this opening and be directed to the drain pan with an air gap.
The primary drain present in the picture also should have a condensate trap present.
When that emergency drain pan rust out due to that moisture its going to be an expensive repair, because the unit will have to be raised to re-install the pan. BIG money.
JMHO
RickComment
Channel: Toyo Heaters
