a/c drip pan full
  • a/c drip pan full
    why is my a/c drip pan full of water and overflowing? i've included a few pics to help explain. i've checked for cloggs in the tube coming out of the pan and it seems to be fine. i used a bicycle pump and air easily rushes through. i stuck a metal coat hanger down the tube that goes into the floor to check for a clog and it seems to stop just below where the other one meets, i think their is another bend their??? anyway, it's been 101 degrees so i'm sure the a/c has been runnng alot.
    its normal to have condensate in the drip pan. the a/c is doing its job of dehumidifying the air. does your drip pan discharge anywhere or is it a close pan with no outlet?
      can you see were the pipe exits the house?? i would guess a clog but with the set up there you would be better off trying to blow it from the discharge end..
      Is it beer thirty??
        did the pics not show up? i think they would explain.
          i did find where it exits the house outside and was told to spray the hose up it from the outside and try to unclog it............that didn't work.
            try from inside then, but you will need to plug that connection on that pan, and feed the hose down too that Tee fitting
            Is it beer thirty??
              that's what i just finished doing and it worked. thanks.
                Late Post Here
                The picture posted has other issues.
                First of all the drip pan is for emergency leaks and should not be full of water at all times.
                If the pan has water in it, it is a indicator that the primary drain line is obstructed. Water is backing up back into the evaporator coil and draining from the bottom into the pan.
                In the picture, the red plug is intended to the secondary drain line which should not be blocked. This should have a PVC pipe attached to this opening and be directed to the drain pan with an air gap.
                The primary drain present in the picture also should have a condensate trap present.
                When that emergency drain pan rust out due to that moisture its going to be an expensive repair, because the unit will have to be raised to re-install the pan. BIG money.
                JMHO
                Rick
