I have a 6 year old Coleman Evcon horizontal natural gas furnace, model CGH050010 or (something like that). Over the past weekend, I turned it off at the thermostat and circuit breaker to clean the filter, and when I turned it back on, it didn't run. It has an automatic pilot, so it's supposed to relight itself. But it's not getting any poer at all because the blower won't even run. Any help is appreciated.
Coleman Evcon won't fire up
FYI I fixed the problem. I did not realize there is a safety switch behind the panel that gets removed when servicing the filter. When putting the panel back in place, the panel must depress the switch. Mine wasn't making contact, so I bent the bracket that holds the switch, out towards the panel a bit. After that it worked fine. Easy fix, lesson learned.
Channel: Toyo Heaters
