I think my AC Blower Died
  • Cody_Norris
    Hello All,
    I am a new user and need assistance if possible. When I returned from work this evening and tried to turn my AC on (I live in Austin Tx and it's 70+ degrees here) I heard this weird humming/whining noise. It sounds like a motor that is having a hard time turning on. The unit keeps making the noise, however it wont come on. The sounds seems to be coming from right above the air filter.
    Thanks!
    Cody
  • irregularjoe
    • Nov 2003
    • 176
    sounds like a bad blower bearing or bad motor. Unplug the unit and remove the filter. You should be able to see the blower (looks like a fan). see if you can turn it manually. BE SURE TO TURN THE POWER OFF FIRST!
    • Hube
      • Nov 2003
      • 453
      Joe could be right on target, but also check out the "start capacitor" for it. Hube
