Okay, so after a very long day at a new house, I have run across a problem that I am not sure how to best tackle. Any advice would be helpful.
Walked in today and the temp was 53. Turns out the igniter was out, so picked up a new one and installed it. Things looked good. However, after two hours, the temp had only gone up 2 degrees. Went down to the furnace and noticed that it would run for 2 minutes of flame, kick off, wait 30 seconds and kick back on. Was thinking that the high light switch was to blame, but it turns our that it is working correctly.
So we begin to look for air obstructions in the airflow system to see why it is not getting enough air to cool down the unit. After removing the A coil from the system, we doubled the output of the furnace at the ducts and was able to get the furnace to run for a longer period, but it was still turning off at a fairly regular interval.
We removed the filter from the system, it was a 3m filtrete filter that is supposed to catch a bunch of stuff. With the Acoil out and the filter out all together, the system is able to run indefinitely. However you put either back in, the system will over heat and start to cycle.
Guess the problem that I am having is it seems like a design problem or something with the blower motor. Not sure that it is the motor, as it runs, just not enough air moving through. If I put the A coil back in, the system will have the same problem. There has been someone out to repair the system every year, it and seems like all the problems are related to overheating and constant cycling.
The furnace is an amana Air Command 90, that was installed about 98 or so I am guessing by the stickers and history of repair.
Is there anything I can do short of just replacing the system??
Thanks bunches.
Jeff
Thanks bunches.
Jeff
