Our new house (not brand new) has gas logs in the fireplace. Is it advised to have the chimney cleaned before using the logs? How much heat goes up the chimney with the gas logs vs. wood? What is the chances of the chimney catching on fire with gas logs? I have never had the gas logs but I hate fire places and fire. Thanks
Gas Log Question
I don't think you have to worry about gas logs. they're merely ceramic or porcelain castings made to look like wood. underneath inside is a natural or propane gas burner. the flame heats the logs and they radiate heat into a room. no creosote is generated so you don't have to worry about a chimney fire.
Channel: Toyo Heaters
