I have hot water heat in my house and all the rooms work but one bedroom. I have tried to drain the air out of the pipes but it doesn't seem to work. Any ideas of how I can get the one room working again?
Baseboard Heat problem in 1 room only?
Tags: None
I;m not sure of yourself but when you bleed a rad you must turn off the boiler and wait a few minutes then bleed the rad with the boiler off this will allow the air to rise and the water to drop try this if it doesn;t work it may be a cloged valve (is there a seperate thermastat for that room?)it could be the zone valve if so . -
I tried bleeding the rad after having the heat off for 2 hours. still no avail i cannot get that one bedroom's heat working.Comment
Channel: HVAC
