ANY INFO FOR SIZING ORFICES TO CONVERT A FURNACE FROM NAT. GAS TO LP?
NAT. TO LP
BERTHA
Welcome to the Home Repair Forums
There is no sizing chart that would specify the right orifice for your furnace except the manufactures parts break down. Typically they are sold in a kit form which give you the proper orifices and springs for the valve which would allow you to run your LP as the proper water column.
Check with your local contractor for the proper part.
16x80
Channel: Toyo Heaters
