have a code 33. Any ideas?
Bryant Plus 90i Furnace won't ignite
On mine it says "limit switch is / has opened".. Basically what has happened is the furnace has gotten too hot and the high limit switch has opened up, could be because of plugged filters or whatever. If it REMAINS OPEN for more than 3 minutes the code will change to a "13" and the heat will lock itself out for 3-hours. Hope this helps!quote:Originally posted by pbush
A.D
Channel: HVAC
