Arlington, VA - Is this a BAD estimate for Radiator/Boiler System Repairs?
  • sonny4753
    • Aug 2007
    OK, have a leaking radiator valve, and a leaking pipe that feeds the radiator valve, and I had a local company come out and give an estimate for 920.00 dollars.
    Am I getting ripped off?
    Here is the description from the estimate:
    "Need to drain down the boiler. Replace both parts need to then refill, purge air and inspect for leaks."
    Radiator Valve: 275.00
    Boiler Drain: 145.00
    Drain Refill and Purge: 500.00
    I'll post pictures in a few...thoughts?
