Installing digital programmable thermostats
  • Jimmer
    • Oct 2003
    • 274
    #16
    Beezer12,
    I believe what you are looking at is a 240 v heating circuit. The thermostats are switching the black and red wires (both carry 120v) to the heaters. The new thermostat you have is for low voltage system with a central heater and/or AC unit. You can get programmable thermostats for the 240v system.
    You can get single pole or double pole 240 v thermostats. The single pole only switches one of the hots on and off while the double pole turns both hots on and off. The doubles cost abit more.
    Good luck, Jim
    • beezer12
      • Nov 2003
      Thanks Jimmer! I'll go buy a thermostat for a 240V system.
      • neal101
        • Nov 2003
        Help!
        Old thermostat burned out (actually smoking)the first time I tried to switch from AC to heat. I tried to install a new one last night and now nothing works. Turned the breaker back on and none of the wires appear to be getting power. Could I have tripped something along the way? Is the transformer ruined? The old thermostat had Y,G,B,W and R jumped. Instructions told me to re-wire the new one exactly the same. Any advice would be trememdous!!
        • LKral
          • Dec 2003
          Hi - I have a question about a digital thermostat I installed a few days ago. Here's my problem - the furnace hasn't turned on since I've installed it. I followed the given directions closely, but it hasn't turned on. I took a look at the wiring again yesterday, it has 4 wires, and noticed the connection between RC and RH was incomplete, so I put it back in, hoping that would be it. I know I turned the power back on, the fan works. Unfortunately it wasn't. Do you have any recommendations of things I should check out? Any ideas would be greatly appreciated! Thank you!
