Honeywell T8411R losing power intermittently
  • bjoneser
    • Jul 2010
    I have an American Standard Heat Pump, 2 months old. The thermostat loses power, no display nothing works on it and then it will turn back on and the ac will come on for maybe ten minutes and then shuts off again. None of the breakers are flipped and the unit outside the box on the house beside the unit just has a black thing that pulls out and two metal prongs. I'm not sure what to do. ????
    Shanna
    the "thing" outside is a disconnect called a pullout. there are two cartridge fuses inside. this controls the compressor and condenser fan circuits. your thermostat is simply a switch. it uses a triac or diac to switch on and off the cooling and heat circuits.
    • bjoneser
      • Jul 2010
      do you know why
      The thermostat would just lose power and then come back on?
      Shanna
      PS
      Thanks for the update I wont call it a "black thingy" any longer.
      Shanna
      • bjoneser
        • Jul 2010
        I looked online and read the pdf manual they have and could not find a "troubleshooting" area. I know there are not batteries
          then the thermostat is powered off the unit's control circuit of 24 volts AC. check for an inline fuse to the thermostat. are you experiencing power brown outs in your area because lower than operating voltage will cause problems
          • bjoneser
            • Jul 2010
            No outages that I am aware of and not to sound like a imbecile but where would I look for an inline fuse?
              look into the control circuits cabinet for a small inline fuse [glass] or a small cartridge fuse in a holder
