Coleman electric furnace won't shut off...
  • hightechredneck
    • Nov 2010
    unless we kick it off using the breaker on the main service panel. A neighbor mentioned a bad relay but we don't have a manual to help locate it.
    Any advice is greatly appreciated.
    Thanks,
    HTR
  • paul52446m
    • Nov 2009
    • 690
    Thanks,
    HTR
    Try to follow the wires back from the blower and maybe that will
    get you to that relay. I don't know if your relay is made by 110 volt or 24 volt.
    Does the heat elements still work? If not you could have a limit switch that is open and that could close a fan switch. This is going to be hard is you can't ID
    the parts. Do you have a tester? Paul
