Monitor E error codes
    Error codes for Monitor 2200 and 2400
    E-01 At prepurge flamerod sensing flame when there isn't any
    E-05 Voltage to microprocessor incorrect
    E-06 Solenoid pump triac controller malfunction
    E-08 Weak air flow from combustion blower
    E-13 No ignition, pump, igniter, overheat, air switch
    E-14 Flame failure blocked air flow at air inlet
    E-15 Power supply voltage low
    E-16 Blocked air flow path to combustion blower
