Monitor 422 Chamber Rebuild
  • dtjacob
    • Jul 2012
    • 23
    Hi:
    Rebuilt the chamber on my 422 yesterday. Just how much is this thing going to stink when I (hopefully) fire it up???? Probably should leave 1 of the garage doors open????
    Thanks,
    Don
  • dtjacob
    • Jul 2012
    • 23
    Just Fired It Up!!!!
    Hi:
    Opened a garage door & fired it up. Had some yellow flames in the window for a minute or two, probably some stuff burning off, & then it settled down. Running on high I see the burn ring glowing red with a nice blue flame around the perimeter - assuming this is good. The smell is definitely there but not really too bad. Will let it run like this for a hour or so & then I should be able to close the door......
    Don
    • dtjacob
      • Jul 2012
      • 23
      Update
      Well, 2 days later & it's still working GREAT!!!! Really was a pretty straightforward "nuts & bolts" job, not a mind-bender at all.....
      • FordMan59
        • Dec 2011
        • 355
        Glad you got it up and running without any issues.
        • dtjacob
          • Jul 2012
          • 23
          Thanks, this is a GREAT heater!!!!
