monitor 441 flame jump, whossing sound
  • mahrkus33
    • Nov 2014
    My monitor 441 flame jumps and makes a whossing sound when burner is on low headed to high and when going from high to low. when running on high it does not do it.
    it almost acts like a drop of fuel is hitting bottom of burner and igniting.
    any suggestions or ideas on what it could be?
    thanks
  • akaothermick
    Absolutely incompetent
    • Jan 2014
    • 140
    Maybe the burner mat is bad, sounds like its time to inspect the combustion chamber,
      • 755
      I would look at the solenoid damper. More than likely you will have to do the burner cloth and ring as well. Tom
      • mahrkus33
        • Nov 2014
        I had had the unit rebuilt two years ago and when they rebuilt it they said they don't put the burner mat in any more.
        i took it apart and did my usually pre season inspection / cleaning.
        it started doing the flare up last spring.
        thanks
        • mahrkus33
          • Nov 2014
          Thanks I will check out selenide damper.
            • 755
            With out a burner cloth your stove will never run correctly. The fuel will puddle on the bottom and the flame will be very high in the pot. You must use a burner cloth on a M 441.
              If you have FACEBOOK, type Monitor Heaters into the search bar and hit ENTER. There are several repair places that do Monitor motherboards.
