5 year burn chamber rebuild update
    • 758
    #16
    Fordman, Did you get your M422 serviced? I sent you a Private Message. If you're still having trouble post again here.
    Thanks, Tom
    • FordMan59
      • Dec 2011
      • 355
      #17
      Thanks, Tom
      No I haven't serviced it yet. At this point without a better understanding of how to remove the burn chamber and heat exchanger I think it's best I leave it alone until my mind (depression and anxiety) has improved). I'll have to look at your PM to see if it helps. I saw one from you a couple weeks ago but I still don't remember how to remove all the parts to access the chamber/exchanger and get it back together right.
        • 758
        #18
        Fordman,
        I believe you have the Monitor 441/422 manual. Section 5 Servicing, page 39 has the procedure for disassembly of the unit. If you no longer have the manual, I can outline the procedure for you when you are ready.
        I do wish you the best of health,
        • FordMan59
          • Dec 2011
          • 355
          #19
          Tom, I no longer have the manual. I lost it when my old computer went bad and it was on it's hard drive. Please post anything that will be helpful but not something I have to download because the small hard drive on the current computer is full.
            • 758
            #20
            5-4 CLEANING THE BURN CHAMBER & BURNER
            POT
            Under normal running conditions, soot will not
            deposit in great quantities inside the burner, and a
            light covering of soot will not affect the performance
            of the unit thus it need not be cleaned. However, if
            heavy soot built up does occur the unit should be
            opened and cleaned.
            The burner is assembled using gaskets to maintain
            its air tightness. If these gaskets leak, the extra air
            can cause a serious soot problem and or exhaust
            gases to escape into the area being heated.
            NOTE: If any gaskets are torn when components
            are removed, replace. Disconnect power
            supply to unit.
            If cleaning is necessary, use the following method:
            1. On the Monitor 422
            A. Remove louver assembly.
            B. Remove front cover.
            C. Remove top cover and lead wire con-
            nectors.
            D. Remove front and top heat shields that
            cover the bum chamber and their lead
            connectors.
            E. Remove fuel piping from burn chamber.
            F. Remove igniter.
            G. Remove flame detective rod lead from PCB
            (DO NOT REMOVE FROM BURN CHAMBER).
            H. Remove screw at top of burner cap which
            attached it to cabinet. Remove screw at
            back of cabinet from exhaust duct and
            remove the 4 screws holding the burn
            chamber to base.
            I. Rock chamber back and forth lightly, raise
            about 1/2" and remove burn chamber and
            heat exchanger, as one assembly from unit.
            J. Set chamber upside down and remove the
            4 screws which secure the burner pot to
            the burn chamber. Pull the burner pot up and
            out.
            MONITOR HEATINGSYSTEMS
            Section 5: Servicing
            3 Turn counter-clockwise to remove combustion
            ring. If ring does not turn, pull up slightly to
            loosen retaining clips.
            4. Use wire brush to clean inside of combustion
            chamber.
            Vacuum and wipe clean with a waste cloth.
            5. If tar is present on the burner bottom, remove
            the tar by using a flat-bladed screw driver or
            wire brush.then clean the area by using a
            vacuum cleaner etc.
            NOTE: Make sure all air inlet openings are clear.
            6. When cleaning the inside of the burner pot,
            remove the igniter and change the burner cloth by
            the following procedure.
            7 On the Monitor 422
            A. Apply glue<P No8217) on the burner bottom
            Put the burner cloth on the burner bottom,
            afterwards press and straighten out the
            burner cloth so that it is glued flat and even
            on the burner bottom.
            9. Combustion ring may deform and deteriorate
            after several years use and should be cleaned
            and inspected before reinstallation. If combus-
            tion ring is warped, has cracked or is deteriorat-
            ing it should be replaced.
            10. When reassembling the unit check that com-
            bustion ring is positioned with the correct side
            up and is sitting squarely on all three support
            screws(M~422) or pins(M-441) inside the burner
            pot.
            11. Reassemble by reversing the procedure foll-
            owed during disassembly.
            NOTE: Use of the economy plus feature can
            minimize service calls and extend com-
            ponent life.
            • FordMan59
              • Dec 2011
              • 355
              #21
              After nearly 4 years since my wife passed away I finally got where I felt like I could take this 422 apart again and get it back together. For a long time I've been having anxiety and depression problems but things are starting to settle down for me again. I took it apart about a week ago and finally got around to getting it back together today so it should be ready when winter gets here again. I'd been using my other 422 for a backup for the last few years and at the end of last winter it started showing lots of yellow in the flame and cutting off occasionally so it is also going to have to be rebuilt. Maybe I'll get it done in the next few weeks. I once again used McMaster-Carr products for gaskets and burn mat. The flame ring that I had welded around the circumference of the dome had been in service 11 years if I recall correctly. When I took the pot out the flame ring wasn't mushroomed but a large portion of the weld had burnt and chipped away and left large holes. I put a new flame ring in but I kept the old one and am going to see if I can find anyone that thinks they can weld up the holes and make it useable again. I just thought I'd come to the forum and let everyone know how the flame ring I had welded held up.
              • handyandy
                • Sep 2002
                • 210
                #22
                That is amazing on so many levels. Thank you so much for sharing!!!!
                • admin
                  Administrator
                  • Feb 2001
                  • 93
                  #23
                  Fordman, how did it go?
