KWH124 on demand hot water heater
  • OnTheEdge
    • Sep 2015
    • 22
    Anyone have any experience with the Monitor KWH124 instantaneous Kerosene fired water heater?
    Been given one that is supposed to be a working unit but I have no working knowledge of them...
  • akaothermick
    Absolutely incompetent
    • Jan 2014
    • 140
    I have a copy of the Repair manual if you need it, PM me with your EMail
    • OnTheEdge
      • Sep 2015
      • 22
      Thanks AK, I was able to download both the service and owners manuals online.
      • rrob311
        • Nov 2014
        • 86
        I have a pair of them. I have not set them up however. The biggest problem with setting these up I have seen is the flow setting. IE if you are not pulling enough hot water through it it won't turn on. In that case I believe turning down the temperature helps. It can also fluctuate between seasons so you may have to alter the settings then.
        • TechEditor
          • Dec 2014
          • 58
          It helps to have a 40 gal. Fiberglass "Temper" tank in-line on the feed to the water heater. it evens out seasonal water temp variations.
          TechEditor
