Monitor 441 Heater temperature cuts back
  • rfreely
    • Oct 2012
    The below incident has been three days in a row now.
    I had our Monitor 441 Heater set to 74 degrees. Out of no where the set temperature on Monitor dropped back to 70 degrees without us doing anything. I re-established the set temperature to 74 degrees. After approximately 5-7 minutes it did the.same thing.
    I powered off the Monitor, unplugged the unit for about 10 seconds. I then plugged up the Monitor, powered it back on and it works as normal.
    Could someone please offer any suggestions as to what could be causing this condition?
    • 758
    Loose wiring harness connection for indicator board or Reset Thermostat.
