Monitor 441 Heater
  • crann
    replied
    monitor 441
    hay-zee, your help was invaluable. i got into the heater this morning and removed the sump, took it apart ,cleaned it and put it back together. fired it up and it seems to be working fine now. one question , years ago i was cautioned to not use carb cleaner on the small filter but to use contact cleaner only. do you have any opinion on this. also, where can i download the repair manual for the 441?
    again , thanks . this forum is lucky to have such a knowledgeable person as hay-zee who shares his experience freely.
    replied
    ok I'll talk you through the whole thing. unplug the heater. shut off the fuel flow to the heater. on the bottom right side of the heater you'll see a large philips screw. put some rags underneath the heater and remove the screw. kero will come out. on top of the sump is the solenoid pump. remove the two wires at the solenoid. unscrew the brass gland nut and pull out the fuel line. on the right side bottom of the sump, loosen the brass gland nut. remove the four philips screws that hold the sump to the heater cabinet. lift out the sump tank. remove the two machine screws that hold the cover plate on the sump. remove the cover plate with the solenoid pump attached. look inside the sump to see if there's any crap inside. spray liberally with gumout carb cleaner and blow out with compressed air. use some q-tips if you need to with the gumout. remove the two philips screw on the right side of the tank and remove the plate and gasket. pull out the filter screen and clean with gumout. shake it dry and replace it. spring goes in first. now put everything back in reverse order. replace the large philips screw and small o ring gasket. turn on the heater open fuel flow wait a few minutes for the bowl to fill up. the lockout paddle may have tripped. push the metal button to reset it. if the sump overflows again shut off the fuel and see what is hanging up in the sump tank.
  • crann
    replied
    monitor 441
    thanks for the response.i will try tomorrow morning to get into the heater. i can not remember if the fuel sump has an incoming line and a line going out to the burner. if it has 2 lines i am assuming i disconnect both to remove the sump from the unit. in cleaning the sump is there anything i should be aware of .(so as not to break!) sorry but i am a novice at this ,and have not taken apart a sump before. to drain the sump do i undo the cover that holds the small filter? will this drain the whole sump? also, i do not have a parts breakdown/ schematic. can i download the repair manual from the first page of this thread? downloading can take me a while as i have dial up service for my computer. thomas
    replied
    the fuel sump isn't sealed because the fuel is gravity flow. in your case, shut off and unplug the heater. shut off the fuel flow to the heater. remove the front grill, drain what ever fuel is left in the sump. remove the fuel line from the left side of the sump and four phillips screws and remove the sump. take the top plate off and use gumout and clean all the crap out of the sump. it sounds like your toggle over center lockout got stuck. kerosene left sitting gels into a snotty mess. lack of fuel sets the lockout, too much fuel sets the lockout. in either case the lowering or rising of the float seals off the needle valve if it travels to extremes. the newer 2400 only has the high fuel lockout option.
  • crann
    replied
    new member/ 441 problems
    first off , this forum is great and hayzee is due much thanks for his contribution.
    now for my problem: in doing my yearly ,main tank, filter change the canister (general 77 ) sprung a leak and i replaced it with a new canister and filter . leak stops and i turn the main valve ,feeding my monitor 441 heater, on . the heater starts up OK and i let it burn for a few minutes and reset to a lower temperture and it shuts off. i return 15 hours later to find kero overflowing the pan and quite a mess of clean up. i remove the grill and find the right side compartment floor filled with kero. once mopped up i can feel
    wetness at the bottom of the pump housing. the lines going to the pump and burner are dry. my question is , wouldn't the pump housing be a sealed unit ,even if a float was faulty? also, any ideas on why this happened. i think this could have been a much worse situation. i read the posts from this thread and saw no mention of this problem . HELP !!
    my e-mail address is aquinas@syracuse.net if i could get a copy of the repair
    manual it would be invaluable. thanks in advance ! thomas
  • randy j
    replied
    I would like to thank HayZee 518 for all the information he has posted. I just put my Monitor 41 back together after rebuilding the combustion chamber and the combustion fan. It is so quiet I can't tell that its running, Ah but I can feel it!
    replied
    I tried to upload the pdf file I have. My isp wouldn't let it transmit. Please look into the HVAC sub section, monitor heaters for another pdf file someone has saved on a remote site. You can d/l it from there.
  • mrsargemeister
    replied
    my PMs dont seem to be working. My email address is
    mrsargemeister AT yahoo dot com
    thanks for all your help. any other suggestions?
  • mrsargemeister
    replied
    So I was working on my Monitor 41, cleaning the combustion chamber and when I reassembled everything and plugged in the AC cord, nothing works. The display window is completely off and I'm stumped. I double and triple checked all the connectors, and ribbon cables with no luck. I verified that the board is getting 120VAC through the main power connector. I checked various test points on the board and those voltages appear to be normal. All the fuses are good. Any ideas? Does anyone have a monitor 41 service manual?
    replied
    a nice turquoise blue flame is always nice to see. that means the air/fuel ratio is just where it wants to be. the heater's efficiency will be 87% as stated in the manual. somewhere down the line in your maintenance, take the top off the combustion pot, careful not to break any gasket material and look at the burner ring. this thing is like an upside down stainless steel bowl. if it is warped get a new one. warpage is why you see a yellow flame. beyond the ring down in the bottom of the pot is the burner mat. when the heater was new it was glued to the bottom of the pot. the flame rod goes into the side of the pot with two screws. clean it with a solvent. this also has a gasket under the bracket. it's your call to do any maintenance on it. like you said "if it ain't broke, don't fix it!"
  • Pockets
    replied
    Hi Hay,
    I've been reading all the posts here and can easily see you are well aquainted with the Monitor heater. I purchased my Monitor 41 about 15 years ago and installed it myself. I haven't had a single problem in all these years and try to avoid trouble through regular maintenance. Since firing up my heater this fall I noticed that, on start-up, the flame takes about 5 minutes before all the yellow flame disappears. Once it does it's fine, beautiful blue. Is that normal behavior or is it a sign of trouble? Should I replace the mat or other parts or is it a "if it ain't broke don't fix it" thing? I do have the parts available from a local dealer. I would like to get a copy of that service manual you have also. deswallow@gmail.com
    I'm in awe of the time you spend to help all the people that you do on this site. These heaters are a real jewel but the information on them is really scarce. Kinda like prospecting for gold, I've struck a vein here!!!! Thanks, pockets
    replied
    The bearing is a 608Z you have the number upside down. They are the same as used on inline skates. The bore is 8mm.
  • mrsargemeister
    replied
    I removed the combustion motor assembly, took it apart everything looks ok. I think I should replace the bearings anyway. They say "NMB Z809". Its stainless double sealed ball bearing. Is there another size this can cross over to? I cant find any Z809.
    replied
    the sound of the combustion blower on its way out was compared to the whinning sound of a jet engine starting. the motor emits a start sound as it gets up to speed. that little motor has to get a six inch disk up to about 1000 rpm. I wrote an email to mpi asking why they never give out a rebuild manual. they said it was an issue of liability. so, here we are examining a product that needs repair but they won't help us. Oh! but they will! At about $150 an hour just to protect their liability.
  • mrsargemeister
    replied
    Combustion blower question
    Hayzee, thanks for supplying all the technical information in this thread, it is very helpful. I have a question about the combustion blower in my monitor 41. This heater is new to me so I am not sure how its supposed to sound. My combustion motor is not completely silent it does emit a noise louder then I would assume appropriate. Maybe you can tell me if this is normal or not. I have removed the inlet pipe from the back of the unit and the impeller shaft moves smoothly and freely with no freeplay. This would indicate that the bearings are good. What are your thoughts? Do the bearings in this motor need to be lubed? If so is this a difficult job? Thanks for your help!
