I'm new to the sight and you guys seem to have the info I'm looking for. My heater failed last winter in Maine and the pipes froze.(-31deg.) I replaced the mat and all necessary gaskets. The room temp. display is erratic. It may say 45 and fly up to 84 and in a split second drop down to any temp in between. So the burner doesn't have a clue on how it should act. Also the flame is perfect on low and med. burn but, on high burn it flashes every few seconds. As far as the temp issue; I've read the t'shooting charts. They ask if theres 2.8v @ TP4. Easy enough, I'm assuming neg. ground. Is this correct? Causes could be failure of R12, R13, C11, or microprocessor IC1. I can check and replace electronics. Where in the world or who in the world has the processor?
Any help or diretion on this would be MUCH apprecated, before it gets to cold.
Ruggy in Bridgton,ME
