Gas shutoff valve question
  • Alpha
    • 194
    Hi everyone,
    Is it acceptable to use a standard brass ball valve on an indoor natural gas line, or does it need to be specifically rated for gas use? Also, are there any markings or standards I should check to confirm it’s approved for gas service?
    Thanks in advance!​
  • TinyTool
    • 357
    Hi there! You're right to double-check this. Not all brass ball valves are safe for gas. For natural gas lines, the valve should be specifically rated for gas use. Even if it looks the same, a regular valve might not seal properly or hold up over time, which could lead to a dangerous leak.
    To be sure it's approved, look for markings like "CSA" or "AGA" on the valve. These show that it's been tested and certified for gas service. Sometimes the packaging or product listing will also say something like "gas rated" or "suitable for natural gas."
    It’s always better to use the right part and play it safe when working with gas lines.
    • Alpha
      • 194
      Thanks! Would a gas-rated valve also have a pressure rating marked on it?
      • TinyTool
        • 357
        You're welcome! Yes, most gas-rated valves will have a pressure rating printed on them. You’ll often see something like "600 WOG" on the side. That just means it’s rated for 600 PSI and can be used with water, oil, or gas, as long as it’s not for steam.
        WOG is mostly used in the U.S. and in places that follow American plumbing standards. In other countries, they might use different markings like "PN" or labels like "CE" or "EN 331" when something is rated for gas.
        If you're in the U.S., the main thing to look for on a valve for natural gas is a marking like "CSA" or "AGA." That tells you it’s been tested and approved for gas use. If the valve doesn’t mention gas anywhere, it’s safer to avoid using it on a gas line.
        • Alpha
          • 194
          Is there a chance older valves might meet gas standards but not have clear markings? Or is it safest to assume they’re not approved if it’s not labeled?
          • TinyTool
            • 357
            It is possible that some older valves were made to meet gas standards but just don't have clear markings, especially if they were installed before current labeling requirements were in place. That said, if there is no visible certification like CSA, AGA, or a clear "gas rated" label, it's safest to assume the valve is not approved, especially for anything involving natural gas. It's just not worth the risk when it comes to safety. If you're unsure, replacing it with a clearly marked, certified valve is the better option.
            • Alpha
              • 194
              Thanks, one last thing. How is it usually determined when to replace a gas valve in an older installation? Is it only if there’s a visible issue, or is proactive replacement recommended even if it appears to be working fine?
              • TinyTool
                • 357
                You're welcome. In most cases, gas valves are only replaced if there's a specific issue, such as leaking, being seized, hard to turn, or showing visible damage like a worn handle or stem. However, proactive replacement can be a smart move in certain situations, especially if:
                • The valve isn’t marked for gas use and you can’t confirm it’s certified
                • It’s an old plug valve or gate valve, which are more prone to sticking or internal corrosion
                • You’re already working on the gas line and it's convenient to upgrade
                • The valve shows any signs of corrosion or deterioration, even if it still works
                So while age alone isn’t always a reason to replace a gas valve, it's worth considering if there's any doubt about its safety or reliability. When it comes to gas systems, it's always better to err on the side of caution.
                • Alpha
                  • 194
                  Thanks a lot for all the information. Much appreciated!
