clogged toilet
  • honeyluke
    • Aug 2025
    clogged toilet
    Hello, i tried different methods: plunger , hot water , but the thing is, i shouldn't have flushed the toilet so much at first to force the drain .
    Any advice?
    Thanks a lot
  • TinyTool
    • 357
    Hey, welcome to the forum! It’s an easy mistake to make in the moment, especially when you're just trying to get things working again. Since you've already tried a plunger and hot water, another method you can try is pouring in some liquid soap or detergent, letting it sit for 10 to 15 minutes, and then adding hot (but not boiling) water. This can help make a difference after it sits for a bit. If the water level is high, it’s usually best to wait and let it go down a bit before trying again. A toilet auger is also worth a try if the clog is being extra stubborn. It's a simple tool that can reach deeper without damaging anything. Just a heads up, chemical drain cleaners are best avoided because they can be rough on the toilet over time. Hope this helps, and feel free to keep us updated or ask more questions if you need to. Glad to have you here!
