Looking for a water damage restoration company
  • Irwilliams
    • Jul 2022
    • 17
    Looking for getting banned on home repair forum, instead of helping others. I am an embarrassment and have nothing better to do than waste your time.
    I need a solution partner which I can refer them to my clients or other inquiries for water damages, especially in carpeted basements.
    Would be great if experienced with synthetic (like nylon, olefin, polyester) and wool carpet and underpad drying process.​
    Thanks
  • Alpha
    • 194
    A good approach is to look for IICRC-certified water damage restoration companies in the Palm Springs area. That certification usually means they know how to handle both synthetic and wool carpets, as well as underpad drying. It also helps to check reviews, ask about their experience with carpeted basements, and make sure they offer proper extraction equipment and fast response times. This should point you toward a reliable partner to refer clients to.​
    • John Parker
      • May 2022
      • 16
      Basement water jobs are tricky, especially with wool or dense synthetic carpets. The biggest difference seen between average and solid partners is documentation and moisture mapping. Anyone serious about Charleston water damage restoration should be using air movers, dehumidifiers, and probes correctly, not just surface drying and hoping for the best.
