I just had an interior French Drain installed, but no pumps yet.
I thought I had the pump & battery system all figured out, but I'm not crazy about the fact that you have to test & exercise the system at least once a month. Also, with the backup pump, even a $2500 Sumpro battery system has no diagnostics. Then I discovered the "NexPump" system website.
This system sounds great, as it tests itself, however I can find almost no user reports online, at all. I'm hoping someone my have some "real world" information on these. The concept is great, but the pumps themselves seem pretty iffy.
Anyone?
I love the fact that the system checks everything- pumps, battery life, charger, switches, etc. The pumps get dry-tested 2X a day, etc.
OK, the electronics box could fail, but I am considering (literally) installing TWO of these double-pump systems, with one set raised up as a backup system. This would still be less expensive than the system I was about to order.
But I'm hung up on the fact that there is so little user info out there on these. I'm talking about systems that have been in place for 5+ years, and still work perfectly. Nada. No info at all.
I'm also concerned that these are 12v DC pumps, because AS A GENERAL RULE, 12v DC pumps are not as reliable, being designed primarily for short-term bilge operation. The Nexpump pumps are made by Bell & Gossett (ITT.) Is that good or bad?
Also, Nexpump test these pumps dry, and they stay dry in the pit. Can this possibly be OK?
Anyone?
