I am cleaniing a home to rent and tjhe fiberglass tub/shower enclosure is a mess.. It has excessive built up soap scum along with other discoloration due to shampoos or something... I have tried almost every shower cleaner on the shelf at the grocery store with little or very limited success... What can you use to thououghly clean a fiberglass tub / shower enclosure?
Fiberglass Tub Enclosure Cleaning??
Try This...
3M Marine Color Restorer
Restores color to your gelcoat
Resurrect the gloss in your boat's gelcoat with this compound/polish that combines an exceptionally fast cutting compound with a finishing material that removes the fine scratches that compounding normally leaves behind. Removes light to heavy oxidation, scratches, stains, and other blemishes from fiberglass gelcoat.
Contains no wax or silicone
0.52qt.
Works on tubs too...
Now I can Plumb!
Did you know some Redwood Pipe is still in service today. -
Yep! Pretty much anything designed to make a boat pretty will do nicely on a fiberglass tub....I stayed at a Holiday Inn Express last night.
Now I can Plumb!
