Hot Warm Cool Hot
  • DD716TED
    • Nov 2004
    • 220
    Hot Warm Cool Hot
    Lately when taking a shower we have noticed that when set the water temp then it will go real hot..then cool off to cool and never stays the same... this all happens when nothing else in the house such as a second shower or toilet is being used and never happened before... Our water pressure is 35lbs after the plumber installed a new pressure reducer/regulator several months ago. Is this to low or is something else happening??
  • Redwood
    • Feb 2009
    • 512
    The pressure should be fine...
    Your temperature fluctuations are caused by something else.
    How do you make your domestic hot water? Tank Water Heater, Tankless Coil, etc...
    Do you have a mixing valve after the water heater?
    Now I can Plumb!
    • DD716TED
      • Nov 2004
      • 220
      hot water
      The hot water is made with an electric HW heater (New in 2009) and the only other thing installed is the Watts HW recirc system to keep HW readily available at the other end of the house... It has been installed over a year now...
        so you have a hot water loop around the house. are the return lines insulated?
        • Redwood
          • Feb 2009
          • 512
          is there a check valve on the return line?
          Now I can Plumb!
