So... I have a house built in the late 70's in California and want to install a POE water filtration system. It looks to be run with galvanized pipe from the main, with an outside diameter of 1.325". Is this a 1" pipe? I'm concerned that the filter systems on the market that state to have a 1" inlet will be too small. Anyone run into this before?
Thank you!
Kevin
Thank you!
Kevin
