Recently I had a pipe break between my main shutoff valve and the cities water meter out in my yard. So I had to turn the water off at the meter to stop the leak and fix the pipe. The old pipes were steel or lead and I was able to find two connections so that I could replace the leaky pipe with a new PVC pipe. The new PVC is only about a six foot section and is the same diameter as the old pipe. However, since this fix my water pressure has dropped off considerably and I can not even run my sprinkler system anymore. I'm sure I turned the meter all the way back on. Does anyone have any ideas?
Low Water Pressure
