Soft Water
  • rainman
    • Mar 2004
    Soft Water
    I am planning on installing a water softener in my home.
    Will a filter remove the 'sodium' if I soften the entire indoor water supply?
  • Hube
    • Nov 2003
    • 453
    If your concerned with Salt in your diet, why not use a Pottasium to clean (regenerate) the softener. It has the same cleansing effect on the Softener's Resin as salt. It is only slightly more expensive. Hube
    • rainman
      • Mar 2004
      Thanks for the reply, I'm not really concerned about intake as much as flavor. I would prefer soft water as the hard stuff. It is ruining my fixtures, coffee maker, and icemaker. I just wasn't sure how common it was to soften everything.
      • Delsimer
        Most people cant taste the salt. Also you can set up a pre filter loop or by pass for plumbing you dont want to run soft water, i have my out side faucets not soft, my dow stairs work sink is on this line too, but the washer, (cloths and dish) fridge and kitchen are all soft.
